hpad06
September 5, 2010, 4:45pm
1
My dishwasher does not dry completely, so I opened up the bottom inside and finds there is water left there. dishwasher still washes and heat up and I see the pump can get water out however the water will flow back.
I took a picture of the water
pic1 | Flickr - Photo Sharing!
Any suggestions?
I’m not going to type this again, so I suggest that those dealing with partially-performing dishwasher draining systems read this:
http://forum.appliancepartspros.com/dishwasher-repair/118983-kitchenaid-dishwasher-wont-pump-out-all-water.html#post268611
Good luck,
John
hpad06
September 10, 2010, 2:47am
4
Thanks John!
This is the link to my dishwasher manual:
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154737301.pdf
I can’t seem to find water valve for draining, in my case, is it integrated in the drain motor, do I need to replace drain motor?
Thanks a lot!
