Brand:frigidaire Model Number:fgid2479sf7a Main Symptom:dishwasher not draining and pausing mid cycle What happens & when:when i try to run cycle. It won’t complete it and pause mid cycle and if i open the dishwasher there us pool of water / or soap water . I checked the drain hose it looked fine, i cleaned filters as well
No there is no food stuck.. and when i start dishwasher it sounds like working fine.. it stops after some time without completing cycle. Nd there is pool of water at bottom tht wont drain
Here is a tech sheet that will help you enter service mode. I think you may have a bad drain pump, but before replacing it, go into service mode and double-check for any error codes or test results.
