I have tried to clean out all the hoses and I know there is no other clogs because I can just start it again and it will usually finish. For other Gallery dishwashers there are suggestions that a pressure switch replacement is the fix, but there is no pressure switch available for this model (unless it is names as something else)
pressure sensor…part # 5304504077 through appliancepartspros.com
