Frigidaire Dishwasher Leaking
Hello, I have a Frigidaire fdb1450chc2 dishwasher that is leaking. As you can see from the video the water is coming out at the bottom gasket. I have already replaced the bottom gasket with a new one. Sometimes the amount of water coming out is so much, that it leaks onto the floor. I’m just looking for some assistance on how to resolve this issue or find out why the dishwasher is doing this. Attached is a link to the video.
https://www.youtube.com/watch?v=-1dNvLsGMY4
Thank you,
-L
Parts for Frigidaire FDB1450CHC2 Dishwasher - AppliancePartsPros.com
Take a look at the the seal (item 49 in section 05).
If you click on the description or picture a new page will open with more info (video and a Q&A section) which may help.
Remove the spray arm and check it for cracks or partially plugged holes that could spry water at weird angles.
Check if the unit has a splash kit.
Thank you Denman,
I read a few people’s posts about the bottom sprayer having a hole in it causing water to spray out the opening in the bottom gasket, so I have ordered a new bottom sprayer. The gasket was already replaced about two weeks ago. I will post the results once i receive the part.
Thanks Again,
LM
