After completing wash and rinse cycles, the water gushes out of the lower front part of the door right next to where the control wires enter the bottom of the machine. Found and removed a small piece of plastic that was clogging drain line, but it still is leaking. The after wash cycle water is enough to fill a 2 quart saucepan.
[FONT=Times New Roman][SIZE=3][COLOR=#000000][FONT=‘Times New Roman’]Your saying its leaking from the door right? If so t[/FONT]here could be a hole in the wash arm causing water to spray under the door. There is a filter under the wash arm there could be a hole in it or it may not be lying flat causing the same thing. Also sometimes I see them leak through the soap dispenser on the door. Dishwasher Leaking Repair Guide [/COLOR][/SIZE][/FONT]
Replacement parts for FRG FDB2810LDS0 | AppliancePartsPros.com
Check this out from TechnicianBrian’s website
Frigidaire Dishwasher Leaking from the Door
Seems like an awful lot of water.
Is water being left in the bottom of the tub perhaps this is causing an overfill due to poor draining.
