Brand: Frigidaire
Model Number: FFCD2413US2A
Main Symptom: Fails to drain every few cycles
What happens & when: Every 3-4 cycles our dishwasher will not fully drain. Sometime it is most empty and other times it is nearly full. I can manually turn the pump on and it will drain just fine, but I cannot figure out why it does this. I have cleaned out the debris basket and filter and nothing fixes it. When the pump is run manually it sounds just fine. Could this be the control board going bad? I would think if the pump were bad, it wouldn’t work as it does when turned on manually. The plumbing has not changed and the pump sends a strong stream of water into the drain when turned on manually. Thanks for any assistance.
Parts or tests already tried: We typically run the 1-hour cycle, but I did do a full wash test cycle and it worked just fine for six or seven cycles but now ot has started having that issue again.
