Need help locating where defrost timer is on this unit.
No defrost timer. It’s an electronic control and it’s up in the control box in the fridge.
[QUOTE=PNWDrew;910485]No defrost timer. It’s an electronic control and it’s up in the control box in the fridge.[/QUOTE]
Ok. Then if the freezer is not defrosting would you change the thermostat first?
If it’s possible I’d test it first, while iced up so thermostat is closed. If there’s a plug for the defrost element and thermostat at the evaporator a quick test for continuity (or resistance) through it would be all you need. If it is hard wired (and it probably is) you should be able to test up at control.
There’s a wiring diagram in the parts list here.
Full diagram:
Frigidaire A01078804 Control,electonic,w/cover - AppliancePartsPros.com
Strip circuit:
Parts for Frigidaire FFHS2322MBHA: Wiring Schematic Parts - AppliancePartsPros.com
Also a visual check is sometimes enough, if the thermostat is bulging out or looks damaged that’s a good enough sign.
If you don’t have a multimeter to help diagnose, the thermostat is a good guess. It’s cheaper than the board at least. That calrod style element is unlikely to fail.
Will do, thank you for the advice.
