Frigidaire Damper motor continuasly cycling
Due to a power surge i had to replace my ADCII with a ADCIV, this included replacing the damper motor switch from 2 to 1 when installing the new wiring harness. Now the damper motor constantly cycles open - close, etc. I know this will cause problems with the damper motor, please help…
Could you list the part number from the parts you have already installed?
ADC IV Kit 5303918476 included in kit are part #'s
242011001 - ADC IV
241735702 - Control box wiring harness
5303950257 - Instruction sheet
Can anyone please help I still have the same problem and i know this cant be good for the damper motor.
