tan in back of frigidaire cooktop stove shows #316424187 as a model number. Gas range.
Door shuts all the way except what normally pulls it in the final 3/4 inch or so.
I have read posts on this problem. Is there a way to tell if the receiver is the problem or the hinge?
The given model number comes up as a part not a model number.
Please check it.
Remove the door and re-install it.
the operators manual should tell you how to do this.
[quote=denman;848991]The given model number comes up as a part not a model number.
Please check it.
the operators manual should tell you how to do this.[/quote]
The number showing on the back is the only one I can find. Any suggestions on where to look elsewhere? The paperwork is still in a bag on the back of the stove, but no numbers at all listed on the 2 page manual or wiring schematic.
The range in in a bad place to remove the door right now, I will try to do it a little later today. Thank you for the response. Gary
The following may help finding the model number.
Find your model number - AppliancePartsPros.com
How about this one.
Frigidaire FGF366DSA.
I took the door off, reinstalled and it still will not close the last 1/2 inch.
thanks.. gary
Parts for Frigidaire FGF366DSA Range - AppliancePartsPros.com
Below is a link to a manual which may be applicable to your unit.
http://appliancejunk.com/forums/index.php?action=downloads;sa=downfile&id=282;t=1394018785
You will have to join the site and be logged in to be able to download the manual.
Check that the door latch that locks the dooer during self clean is OK.
If it is then you may need new door hinges.
