The other day I ran a load of laundry in my washer and it flooded the laundry room with no error codes. This morning I ran a load and it filled the tub with water then started with an E10 code AND flooded the laundry room at the same time. I can run the spin cycle and it spins out just fine so it is not leaking from the drain hose. Then I started to run a cycle to find out when/where it was leaking. When I did this it started leaking from around the bottom of the washer (I have not taken off the outer cover or anything at this point) and so I immediately canceled the cycle and cleaned up that bit of water again. Then I ran the spin cycle and again no water leaking. It is only leaking when the water is filling the tub. Where should I start looking first? I am only asking this because I literally took my dishwasher completely apart once before and should have looked at the hole that should have been put into the garbage disposal first after being installed. Thank you for all your help. It is greatly appreciated.
Angel
