Frigidaire Affinity Dryer, seem stuck on high heat
Our Frigidaire Affinity Dryer, Mod FAQE 7077 KWO, seems to be stuck on High Heat.
I haven’t found a schematic on the unit or in my paperwork. Is there one inside the unit or one available online?
Any thoughts on what to check first? (the vent is clear)
I placed the unit on “no heat/Fluff” and still have heat.
I’d guess the heat relay is stuck on. Its internal contacts get burnt and stick together.
https://www.appliancepartspros.com/wiring-diagram-parts-for-frigidaire-faqe7077kw0.html
https://www.appliancepartspros.com/controls-top-panel-parts-for-frigidaire-faqe7077kw0.html
Just to follow up, everything ohm’ed OK except the heater coils which showed no continuity.
Found coil broken and steel board holding the coils melted (it’s a wonder it didn’t catch fire.
Replaced heater assembly (checked continuity OK before installing)
Now my problem is no heat, so the mystery continues
