Frigidaire Affinity Dryer AEQB7000ES0 Error Code E56
My dryer will run for about 15 minutes and then stop and the three lights to the right will blink. I unplugged the dryer and plugged it back in. It is running longer than 15 minutes, but it does not seem to be heating up.
I put the dryer in field test mode and the error code received is E5b 006 (Note the error code in post subject is incorrect). It looks like the error is "Heater Fault (no heating) "
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/137058200.pdf
I am guessing that it the heating element, but please let me know if there are any additional tests that I can perform to verify.
Thanks!
Brian
I took the dryer apart and the heating element is broken, so that is definitely it. Thanks
