Our Firgidaire dishwasher FDB2510LCC1 will not drain.
I have checked the outlet hose clean (cannot blow air through it though), inside the unit at the bottom, screen and cup is clean. No kinks in the hose. No change to plumbing.
When we turn on the unit, we do not hear the pump come on to drain. Also when we hit the ‘normal cycle’ button, and start, it goes blank.
Door latch seems secure.
Is the pump of the unit in the back , so I would have to pull it out to check it? or is it underneath the front bottom panel?
