Since replacing my
Frigidaire 134515300 Bellows Kit
I have had a leak. Took machine apart again and can’t seem to find what is wrong.
Did diagnose that the hose is still full of water. Could my drain pump be bad?
Seems like water leaks during when machine is filling up not emptying.
Any help is greatly appreciated.
Thank you,
Laura
Leaks, like noises are very difficult to diagnose without being there, and on front loaders they are very hard to find.
If it is leaking during the fill then the problem is likely in the line coming into the dispenser or the line from the dispenser to the tub. You may have to just replace them if you cannot find the break that is causing the leak. It is also possible that the dispenser assembly has a leak but that is less likely.
