Frigadare Ice maker slowed then stopped
Brand: Frigidare
Model Number: FFHB2740PE8A
Main Symptom: Icemaker slowed then stopped replaced with OEM same ting
Parts or tests already tried: tsested Solenoid for ice maker, is good. Switched plug for door water got woter to icemaker, Made Ice. Does the green solenoid feed the icemaker directly or is there anothe valve? What tells the Ice maker to make ice?
Sounds like this issue will be caused by a water valve which would be in the following link. Frigidaire 242253002 Refrigerator Water Inlet Valve | Genuine OEM Part
I checked the soleniod with an ohm meter and switched plugs from door water to icemaker soleniod and it put water to the ice maker. I do not believe it’s the solenoid. I think it may be the controller if that’s were it gets it’s signal to open.
