Frididaire dishwater leaking underneath
I noticed that our dishwasher was washing the floor as well as our dishes. Water was coming out from underneath ans it was running. I took off the lower front kick panel and watched as I started it. It took about 5 minutes before water started someing out of what looks like the back side of the pump/motor? Is this a gasket problem or am I looking at a complete replacement. I have not pulled the diswaher out yet, so what is the best way to approach this?
Thanks for your help.
Water could leak through the O-ring (#59 on the pump & motor break down diagram) or through the pump seal.
You have to remove the dishwasher from the cabinet to pinpoint the leak.
Post your findings and we will go further.
