Brand: Fridgidaire dishwasher
Model Number:FFID2426TS6A
Main Symptom: Not draining properly
What happens & when:sparadically water remains in bottom of dishwasher and leaks out the front. Sometimes it does drain. Filter clear, garbage disposal line clear. It seems pump does close off when should allowing water back in. Should I replace the water pump assembly, water inlet valve, circulation motor kit or what do you think?
No error codes
