Fridgiaire oven
Brand:fridgiaire oven
Model Number:fgf368gmb
Main Symptom:oven won’t work
What happens & when: The oven shows locked but is not locked. I have unplugged and plugged back in also shut off circuit breaker and turned back on. Then hit clear and lock comes back on one time I could change time then another time I couldn’t I am thinking it is control panel. In the beginning had an f6 error
Error Code (if any):f6loc
Do i have to pull out the wall oven to replace the bulb socket
its a frigidaire mod fgb24l 2ecc
