I have the problem of the freezer is fine but the fridge is warm. I have read numerous posts but when I search for a diagram of my fridge it says there is nothing. There is ice build up in the feezer and I don’t hear a fan turning. Any help would be appreciated. I edited this because the fan in the freezer is turning.
I see Norm Poulin asked about this refrigerator back in 2008 and no one ever replied. I assume I will get the same treatment as I posted this hours ago.
I have no idea why Norm did not get an answer.
This forum is manned by appliance techs and DIYers, all of them are volunteers.
AppliancePartsPros fund this site and do not require anything from you, which I personally think is a very good public service.
Note that I am just a volunteer.
If you need/expect a response ASAP the I would respectfully suggest you try Sears (good luck with that) or one of the sites that will want a credit card number before they answer anything.
OK, there I have vented, now onto your problem.
Replacement parts for KENMORE 596.51673100 | AppliancePartsPros.com
Unfortunately there is no parts breakdown diagrams.
The unit is actually an Amana made by Whirlpool.
I have no way of cross referencing Sears model numbers to the actual manufacturers number and Sears does not give out any technical data.
[COLOR=“Blue”]There is ice build up in the feezer[/COLOR]
Could be you have a defrost problem. It will show up first in the fresh food side and later in the freezer side. Remove the evaporator cover from inside the freezer so you can check the coils. If they are heavily frosted/iced up then defrost is not working and the fan cannot circulate air through the coils to cool it properly or push it into the fresh food side.
Usually this is troubleshot by forcing a defrost but I do not know how to do this on this unit. Hopefully someone else will jump in who does know.
You could try unplugging the unit then plugging it back in. See Page 40 in the below manual or by hitting the door switch 5 times in 6 seconds. You will know when it goes into defrost as the compressor and the fans will shut off.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8e95092d16f05e168525744800711fe0/$FILE/defrost_systems.pdf
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the defrost control board needs replacing, as it is not cycling automatically into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Note: If you cannot force a defrost then check the heater and the defrost thermostat, if both OK then I would assume that the defrost board is shot. Only other cause I can think of is a bad wire or connection.
Denman you are the best I want to thank you for working so hard to help.
Post edited by admin
Looks like he came back a second time and edited the post
“I edited this because the fan in the freezer is turning.”
Though it may be a mute point as it does not look like he has returned to pick up any posts.
May not even be a defrost problem I guess we will have to wait and see.
denman
When a junior member starts calling others names and the mods think it’s ok, I’m not interested. I have fixed the problem after waiting half the day for a response. I’m a computer tech and very familiar with electronics. As far as being a “numbnuts” maybe tex should check his own.
I might be wrong, but I think texsyn’s sense of humor driven foot accidentally got stuck in the wrong place
I really don’t think he was trying to insult you stratblast, as he himself was here to ask for help (http://forum.appliancepartspros.com/refrigerator-freezer-repair/100206-holy-moly-my-bx22s5w-p1196708ww-done-broke.html#post228737), and thus had to have been referring to himself, right texsyn?
In any case, I will go ahead and edit the post in question. Verbal abuse and disrespectful statements towards other members are certainly not allowed here.
Oops my bad. Sorry should not have said what I did.
OK , Sweet , Very helpfull thread . So my defrost control bourd is bad . Where is it located on the kenmore 596.52673200 ? Also Ive forced my unit into defrost ,"door switch 5 times really quick " , and completely dried it up in there , but I was wondering how often the heating coil turns on to defrost . Will I be ok for a few days until I can get a new defrost control bourd ? Im thinking it operates on average once a month ? Should be fine ?
You guys and this forum ROCK ! ! !
PS Im new here , I frequent another forum and if you read some of the stuff the mopedarmy.com people typed you’d have a melt down .
Looks like it is in the fresh food section, see the attachment. It is Item 6.
[COLOR=“Blue”]Will I be ok for a few days until I can get a new defrost control bourd ? Im thinking it operates on average once a month ? Should be fine ?[/COLOR]
It should be OK for a few days.
The cycle depends on how often the doors are opened. Usually it will defrost every day or less but it takes a while for the frost to build up to where it causes a problem.
