My Fridge is a side-by-side. It has an adaptive defrost control module instead of a defrost timer. Also, its temperature set thermostat is in front and has a “long reach” sensor tube that reaches all the way to rear wall of the refrigerator and the air exchange damper to the freezer.
I’d like to perform the ohmmeter thermostat test they talk about in the Kenmore DIY manual I bought. However:
- Those thermostats are for refrigerators units mounted in the rear, use defrost timers, and don’t look like mine;
- I don’t seem to get the results they describe; and
- So I feel I don’t really understand what test conditions they are setting up, or what constitutes valid, or invalid results.
[Thermostat
P/N: WHIRLPOOL 2198202; AP3037004]
For example, I’m expecting that when the thermostat allows the fridge to cool, it acts like a zero ohm or nearly zero ohm resistor. If this is true, how close to zero must it be to be considered OK? Asked another way, when do we consider “almost zero” not close enough and thus faulty?
Then, when the fridge approaches the set temp, does it act like a dimmer switch or an ON-OFF switch? Asked another way, is there a measured value of resistance “we” consider OPEN or infinite that is not really OPEN?
Also, the "long reach stem? on the thermostat in my fridge has a cover on it its entire length. I assume this is an important part of it, but why? And how does one change the temp of the thermostat for the purpose of a test?
[Tube barrier, thernostat (fc)
P/N: WHIRLPOOL 2196003; AP3041744]
I hope there are others out there who want to know about this too, or who know and are willing to share their knowledge.
