the fridge is freezing things and the temperature is flashing 4. I adjust the freezer temp to 0 and the fridge temp to 34, and within the seconds the fridge temp flashes 4. The control unit was bad and i replaced it, and since replacing, this has been occuring. Thanks!
I cannot be of much help here but perhaps running the diagnostics i will help.
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241636601.pdf
Here is a manual
http://frigidaireservicetips.com/pdfs/496_4.pdf
Hopefully someone else will jump in with a solution.
