Brand: whirlpool
Model Number: wrs555sihz00
Main Symptom: fridge not freezing/cooling
What happens & when: plug in, lights on, fans running, compressor working, condenser coils not dirty, stops running when doors are opened, very little air blowing from freezer vents
Check the frost pattern on the evaporator, is it iced over or completely/almost completely clear of frost?
the evaporator should be frost free as the refrigerator has not been used for a year, had been working fine before, had been transported to this new location last year.
If it is running then there should be a full frost pattern on the evaporator while the compressor is running. If it is iced over then you have a defrost problem, if it has a weak/light/partial frost pattern then you have a sealed system issue.
