Fridge has no power, lights are on
My whirlpool plus gold fridge compressor and fans do not work. But the lights come on. I replace the compressor relay and capacitor. I have tested the thermostat and door switch and its good. Any ideas. Thanks
Parts for Whirlpool GD5SHAXKQ00 Refrigerator - AppliancePartsPros.com
Sounds like a defrost board problem.
You could check for 120 volts at the board (BK to WH). (Input power)
If OK then OR to WH (thermostat/compressor power)
GD5SH.pdf (543.9 KB)
