Fridge & frezer not cooling
Brand:
Model Number:wrf560sfym04
Main Symptom:not cooling
What happens & when:not cooling fridge or freeze
not cooling. 2014 model. compr hums & fan works. cleaned coils. thinking it bad compressor or loss of coolant. any ideas?
Check the evaporator coil and see if there is an even frost pattern. If there is not an even frost pattern then this will be a sealed system leak or a faulty compressor in which you would need to have service to repair.
