Fridge & Freezer Repair – Troubleshooting Rules
Warm fridge, iced coils, noisy compressor? Troubleshoot cooling issues here.
Post title must be: brand + full model number + main symptom
Example: “LG LFXS28566S freezer warm, fridge cool”
Body checklist:
• Fresh-food and freezer temps
• Frost pattern description or photo
• Fan noises, relay clicks, error codes
• Parts swapped or diagnostic results
Before posting, run a quick search in this forum to see if your issue is already solved. If you suspect a bad part, paste the exact AppliancePartsPros.com product URL so others can confirm it fits your model.
FRIGIDAIRE/ELECTROLUX refrigerator, model #FFTR2021TWA, serial #4A13409386
The compressor and evaporator fan appears to be operational but the freezer is at 50°F while running the refrigerator part is also in the 50s. I bought it new and it always seemed to be running with quite a bit of nosey.
I have pulled the run capacitor and discharged it. I tested it with a multi meter. No continuity and using the diode selection with nothing.
I am posting this for opinions on what components to check and how to check them. Hoping it’s the run capacitor but i rarely have luck in such things.
pulled the cover from the inside rear of the freezer and tested the evaporator fan and no continuity between the power leads?
Thank you for your time and effort in advance.
