Fridge/freezer no longer cooling
Brand:Kenmore
**Model Number:**106.44322400
Main Symptom:No longer cooling and freezing, light blinking
What happens & when:3 days ago
Is the compressor running? What light is blinking?
The blinking light is the light that turns on when you open the door. Can I check the compressor status without opening the back panel? Thanks!
You should be able to hear the compressor running if it is.
You might try turning off the appliance at the breaker or unplugging it and accessing the evaporator fan to disconnect it. That fan failing can cause some odd issues. Once it has been disconnected you can reconnect the appliance to power and see if the flashing lights go away and if the unit seems to start cooling.
