i have been experiencing problems with the fan and replaced with new one and still not working tested power coming out of harness and received correct reading now confused?
What fan are you talking about - the evaporator fan or the condenser fan?
How did you test the power to the fan motor?
it’s the evaporater fan which has a digital control board in the back of the fridge
[QUOTE=jb2008;18821]it’s the evaporater fan which has a digital control board in the back of the fridge[/QUOTE]
In most cases the evaporator fan motor has to be replaced together with the main control board.
- The part number for the main control board is [COLOR=#800080]AP3950129[/COLOR]
Here are the break down diagrams for the GE refrigerator Model GTS22IBMARWW
I need to remove and replace a fan from a GE freezer. Can you tell me how you removed the fan from the little pin holding it in place?
Tari, do you have a model#
Tari, I’m not sure I understand what pin your talking about. The fan is mounted to a bracket, that attaches to the plastic support orifice. you should be able to unscrew the motor mount from the plastic, remove it, and get access to the fan
The little pin the fan spins on. I think the back side of the pin (deeper in the freezer closer to the wall) is then attached to the motor that spins it.
You want to know how to replace the fan blade or the fan motor? If you just need to replace the blade, just pull it off the shaft
I just need to replace the fan blade, not the motor. I can’t get the blade off of the shaft. That is the problem.
And we still need the model number.
It should slide right off the shaft with some force, there is nothing holding it there, just a compresion ring, but you dont need to remove that
