I thought I had this problem resolved by replacing the start relay but that did not work. The compressor unit tries to start-up but shuts down within 1 minute. Not sure what to do next. The unit is just over 5 years old and I cant believe the compressor is wasted already. Any thoughts? Thanks
snyc
Unfortunately the compressor is gone.
The compressor has to be replaced and you need a certified tech to do it for you.
I had a feeling that the compressor was gone. After checking with the Mfg. the unit is still within warranty, but only by days so I lucked out. Guess I will play it safe and buy that extended warranty next time I buy a new fridge.
sync
i think i may have the same problem but wanted to ask someone first the fridge/freezer was making a loud buzzing noise for awhile in till 2 weeks ago the freezer packed in and the fridge any idea what it is as the person who sold it to use keep fobbing us off saying he be round to fix it and has not turned up and making excuses etc he says if its the relay its not worth doing…
