I cannot find info on the given model number, please check it.
I am going to assume (the parts are probably the same) that the unit is an FHSS01.
Replacement parts for WHIRLPOOL KSRB25FHSS01 | AppliancePartsPros.com
I am assuming that your coil was heavily frosted to the point that the evaporator fan could not pull air through it.
Here is the tech sheet,see attachment.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
Manually force a defrost cycle, see the tech sheet. The fans and compressor will turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the adaptive defrost board (Item 6 in Section 10) needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 33in Section 11) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 35 in Section 11) and measure it, should be 0 ohms when frozen. Note: that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost relay contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
KRSB25.pdf (374.3 KB)
