My fridge and freezer automatically shuts off. the temperature display stays lit with the numbers of what the temperature was set to so it looks like it is working. If I unplug the fridge and plug it back in it starts to work for a while and then shuts off again. When I open up the refridgerator I hear the compressor running but don’t feel any air coming out. Any idea what is wrong?
[QUOTE=Frantictx;90271]My fridge and freezer automatically shuts off. the temperature display stays lit with the numbers of what the temperature was set to so it looks like it is working. If I unplug the fridge and plug it back in it starts to work for a while and then shuts off again. When I open up the refridgerator I hear the compressor running but don’t feel any air coming out. Any idea what is wrong?[/QUOTE]
It will shut off when the selected temp is reached. Will it come back on later by itself or if you select a lower temp.
It will shut off during the defrost cycle and come back on in 20 or 25 minutes.
You have a fan in the freezer to blow the air to the fridge and circulate in the freezer. Is it running? You may have to hold the door switch in for it to run.
Are the temps in the freezer around 10 degrees and fridge around 40.
The refrigerator stops working. We have it set for 0 and 34 degrees. When we unplug and then plug the refridgerator back in the temperature shows 40 and 50 degress. The refridgerator will start running for awhile and the tempratures will start to go down. Then the display will switch to 0 and 34 degrees. If we unplug and plug in the refridgerator the cycle will repeat. We are currently have the refridgerator on a timer so that it turns off and then on every 6 hours. This keeps the freezer below freezing and the fridge around 40 degrees.
