freezer's magnetic gasket not attracting to the door frame
In the freezer the bulb and door magnrtic gasket stop working. In refrigirator everything is OK.
Which device I have to replace to maake door magnetic gasket to attract to the door frame again.
Thanks, for your help
[quote=imedge;445294]In the freezer the bulb and door magnrtic gasket stop working. In refrigirator everything is OK.
Thanks, for your help[/quote]
You may not need any parts at all, other than a light bulb,
First check and make sure there are no articles on the shelves or in the door bins, holding the door open.
Check and make sure the refrigerator is level, and setting on all 4 roller supports, solidly.
If that doesnt solve the problem, you’ll need to check the freezer door and hinges to see if they’re bent,loose, or have debris on the hinge plate on the bottom hinge.
