My evaporator fan started making noise several days ago, and parts in the freezer were icing up. I had replaced the defrost timer about three months ago, but figured it must have been a bad part. So I thawed out the freezer, replaced the defrost timer, and everything worked okay…for awhile.
Someone suggested that the evaporator fan motor was bad, which I doubted, but I replaced it anyway. That didn’t fix the problem either. The defrost thermostat was replaced three months ago also, and doesn’t have a bulge, and though my knowledge is limited, I don’t think that is the problem either.
Throughout this ordeal, my freezer would run for 3 to 8 hours. Aside from a little excess build up on the coils, there would be a lot of ice on the defrost timer and the wire harnesses. When this happens, it reaches a point where the evaporator fan stops running, the defrost timer won’t work (even manually) and the compressor won’t come on. When I melt all the ice and turn the power back on, everything runs fine, and will continue to do so, as long as I manually turn the defrost timer. Sometimes the defrost timer would work on it’s own, but everything is so unpredictable, I preferred to do it manually every few hours to make sure the refrigerator would continue to run. While this worked well during the day, I’d run into trouble over night, when the unit would run for several hours without frequent defrosting, then everything would freeze up again (in the freezer).
A few days ago, I turned the freezer temperature control knob down to see if the same pattern continued, and the problem escalated. Freezing would occur very fast…less than an hour, seemingly almost immediately. When this happened (and I even left the refrigerator unplugged for about 36 hours) the compressor didn’t seem to want to kick off.
The refrigerator was nice an cold while the unit was working, so I’m thinking it’s not the Control Damper. I suspect the Freezer Temperature Control Thermostat assembly, but I don’t understand things enough to be certain. Thanks for the input.
