Freezer temp too cold
Mornin
Freezer temp is too cold thermo is pegged @ - 20 F – unable to adjust temp
Fridge is ok –
I could not find any info on the given model number.
The following is for a KRS25ILBL13 (an i not a 1).
Replacement parts for Whirlpool KSRS25ILBT13 REFRIGERATOR | AppliancePartsPros.com
Following is a service manual. It does not list your unit so I am not sure how close of a match it is.
http://appliancejunk.com/forums/index.php?action=downloads;sa=downfile&id=215;t=1336391376
I would run the diagnostics in the tech sheet.
If OK then check the freezer thermistor for resistance.
If OK then odds are the control board is the problem.
KRS25i.pdf (709.7 KB)
