Freezer temp above 20 degrees F
Temp at top shelf 20 degrees and varies from 30-40 degrees F at bottom shelf. Please help troubleshoot problem. Thank You.
First is your compressor running? Do you feel heat on the condensor? second is their ice or frost built up on your evaporator cover? Do you hear your evaporator fan running?
