Freezer runs but doesn't get cold
My 14cu freezer seems to run fine but never gets cold. It’s super old but clean and would like to salvage if possible. Cant find where to add freeon or any info-Help!
I cannot find any info on this unit.
I am assuming it is a manual defrost type freezer.
You need a pro to fix it and this will be expensive, better off buying a new unit.
There is no use adding freon unless the leak is found and repaired.
