We have a Montgomery Ward upright freezer. The refrigerant coil runs under each shelf of the freezer and one of the coils has a hole in it. Can it be replaced or fixed?
It can be fixed if it was shut off right after the puncture, but the system will need to be vacuumed, the hole fixed, then re-charged. Unit probably not worth the expense.
My freezer is all done freezing, it has been cleaned out of all frost inside and it does nothing, turning it off and back on results in a humming sound for about thirty seconds, then nothing, Help, my ice cream is crying!![]()
Re-post with all the boxes filled in.
