i have a upright freezer; not sure of model; not where i can look right now; this freezer works great untill i have power outtage; even the shortest flicker will cause it to quit working; then i unplug to reset and it is fine untill i have another outtage then i have to reset again; been doing this for about 2 years and no problems; but my son now lives in the house where it’s at and i’m afraid he will forget to reset it and lose everything.
Just wondering if there is a fix for it and if so; is it worth the trouble;
any and all info greatly appreachated.
[quote=daddyrog;774129]i have a upright freezer; not sure of model; not where i can look right now; this freezer works great untill i have power outtage; even the shortest flicker will cause it to quit working; then i unplug to reset and it is fine untill i have another outtage then i have to reset again; been doing this for about 2 years and no problems; but my son now lives in the house where it’s at and i’m afraid he will forget to reset it and lose everything.
any and all info greatly appreachated.[/quote]
over 100 views and no replys; please need help; I’m sure it’s probally a relay or something but don’t know what; thanks daddyrog.
If this is an inexpensive freezer with no self defrost, it’s possible the cold control is defective and will not auto-turn on once power is restored.
If an expensive one with a defrost control, check for a service sheet behind the front kick panel. Will give diagnostics for this problem.
[quote=richappy;777131]If this is an inexpensive freezer with no self defrost, it’s possible the cold control is defective and will not auto-turn on once power is restored.
If an expensive one with a defrost control, check for a service sheet behind the front kick panel. Will give diagnostics for this problem.[/quote]
It is a kenmore frostfree; no service sheet to be found
Look for a control module, probably bad.
This is difficult to give a fix, a model number may help.
Post it if you can get it.
Find your model number - AppliancePartsPros.com
Even with the number it probably will just be a guess.
richappy: Have you ever seen this problem?
Seems to me very weird as a power outage would be the same as unplugging the unit which he has to do to get it to work.
Perhaps the best solution is to get a freezer alarm, just Google it.
It would give an alarm if the temperature gets too warm.
Problem is that it is useless unless you are at home.
I have seen burnt connections that re-connect when power is removed, then turned on. Have seen cold controls do this also.
mod. # 253-26452100
Thanks to all for the help; daddyrog.
I might add that if the power outtage is for more than 30 min. it might would start back ok; never tried it; but with a very short outtage it takes unpluging to get back started; like it has to reset or something.
Parts for Kenmore Freezer 25326452100 - AppliancePartsPros.com
You are probably correct in saying that the control board is resetting when you unplug it.
You could try replacing the control but it is a gamble whether it will fix anything.
Check to be sure that the ground from the line cord is attached to the units frame.
