Freezer not quite cold enough
We noticed recently that the freezer isn’t quite as cold as it used to be. Here are the bullet points:
  • The freezer door was stuck open a crack for a few hours, but it has now been closed almost 48 hours with no return to normal.
  • Both fridge and freezer are set to coldest position.
  • The freezer freezes (still makes ice in the automatic icemaker), but things like bread aren’t frozen solid.
  • I put a glass of water in both fridge and freezer; after 3 hours, fridge water was at ~37F (cold enough, but seems to me it should be colder on the coldest setting). The freezer glass wasn’t yet frozen solid, but had a solid layer on top and around the glass (you could see water in middle)
Pulled the back panel off, and things aren’t crazy dirty. However, the condensor fan is not running. That being said, I’m not sure when it should be running.
Also, the seal to the freezer does have a tear in it, but I don’t feel cold near the tear.
One last thing, the enclosure seems hotter than normal. Using an IR thermometer, the black side is ~105F in one spot behind the ice maker, and mostly 70s elsewhere.
So, just replace the seal, or should I be investigating the condensor fan? Or something else?
Thank you!
The same problem was happened with me last month. I think the problem is in the rubber which is affix with the door. If there is no problem. You should check the compressor of your fridge .
please you can contact to service centre this the best option for you.
