My frigidaire fridge, model number FRIGIDAIRE model FRS26HF5AB3 Frigidaire/refrigerator, (sorry, but I don’t have the serial number with me here at work) the freezer section is somewhat warmer than it should be (~31 Deg F) so I’ve tried cleaning the condensor coils and explored around a bit to locate the adaptive defrost circuit board and the evaporator coils, but I’m not exactly sure what to look for first, or what diagnostic procedures to use …
Replacement parts for FRIGIDAIRE FRS26HF5AB3 Frigidaire/refrigerator | AppliancePartsPros.com
Here is the tech sheet.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389607.pdf
You do not have a defrost timer. The unit uses an adaptive defrost control (Item 23 in Section 5)
First you have to find out what runs and what does not.
Compressor, condenser/compressor fan and the evaporator fan.
Also is the compressor on all the time or is it cycling on/off?
If it is cycling then it could be a thermostat problem.
If on all the time remove the cover from inside the freezer so you can inspect the coils.
If there is no frost por just frost in one area you have a sealed system problem.
Note: This test must be done after the unit has run a couple hours. If checked right after a defrost cycle there will be no frost.
If they are heavily iced/frosted over you have a defrost problem.
Do not let them defrost
If yes.
Manually force a defrost cycle, see the tech sheet. The fans and compressor will turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 14 in Section 6) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 21 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast.
Thank you for the thoughtful reply… I am betting I have a defective “adaptive Defrost” board… I checked the eveporator and it had a solid blob of ice on the top hapl and on the freezer “frost detector” I measured ~1 ohm when cold and 10 meg ohm when warm … so I’m thinking it still works. waddia think? I am a nasa nerd so no need to spoon feed the working of a Volt ohm meter, I own a Fluke DVM, so I’m good there. thanks again.
Yes, the defrost thermostat looks OK.
What did the defrost heater read?
If both OK then odds are that it is the adaptive defrost board.
You said the evaporator coils were iced up in one area, this does not point to a defrost problem.
For defrost to cause problems the coils have to be frosted/iced up to the point that the evaporator fan cannot pull air through them to cool it properly.
Frost in only one area points towards a low freon condition.
Here is a link
http://www.applianceaid.com/refrigerator.html
Check out #20 and the 3 example pictures part way down the page.
If this is the case it will be an expensive repair as you will need a pro.
Often it makes more sense to put those dollars towards a new unit.
I just tried the manual defrost cycle … I hear a loud click from the Adaptive Defrost board, but the compressor still runs … does this confirm its an "adaptive Defrost Board (item 23 on sheet 6)??? Please respond … and Thanks!
The evaporator coils were a solid blob of ice on the top half … I don’t suspect low freon just yet … but i’d like to be a little more sure than I am now( I never like R&TR mechanics … the jus remove and replace 'til it’s fixed … usually randomly)
Yes it sounds like the adaptive defrost board is toast.
We called R&TR, Plug & Chug - just keep plugging in parts till the unit starts to chug along.
I also have friends in the HVAC Business and if the Adaptive Defrost board does not do it, i’ll get a professional friend (a youngster I used to coach) to take a whack at recharging the system. if its anything like our car AC systems, one good shot will get it performing better for a year or more!
Denman, I just got home from a weekend out of town and the freezer is WAY too warm, it was hovering around 31 deg when I left but now its ~65 degrees!
I know you said not to defrost it manually, but I had defrost it manually before i got your first note, the defrost board I ordered should show up tomorrow or so, but I can’t help but think I screwed something up! The evap coils have just a touch of frost on the top. so how does a professional such as yourself actually check the freon charge and put more freon in if needed.
I am not a pro.
To check the freon charge correctly you need a set of gauges.
If the unit only has frost/ice where the freon enters the evaporator coils and the compressor is running continuously then there is a sealed system problem. Usually it is low freon but could also be a compressor problem or a partially plugged orifice.
The system should be evacuated and then re-filled and special equipment is required also most places require that the tech be certified to do this work.
Gets expensive with no guarantee of a long term fix.
Putting hundreds of dollars into a unit to get perhaps an extra year out of it just does not make sense to me. You may get a couple months or a few years or even longer, I cannot say as it depends what is wrong with it but just to diagnose it will probably set you back a couple hundred.
Denman, the adaptive defrost board came yesterday and I attempted to pu it in … but there are just a few differences between the old and the new. It has obviously been redesegned, with about 90% of the connections being a direct and obvious fit, however there are a few minor thigs that at this point, I just guessing, for example, there is no Pink wire at all and the one from the old unit has a few extra things on it. there are a few others, but is there a manual that says what to switch and how to make up the differences? - Jerry K
I could not find any info but I will post in the tech section to see if someone else has the info you need.
Thanks … I’m looking over the schemstics carefully to see if there’s an obvious thing that needs to be brough tover from what’s there already … but this pesky day job keeps getting in the way! - Jerry K
Denman … any luck yet? The schematics you sent don’t exactly match the replacement “Adaptive Defrost Circuit” I received, but I should be able to see what’s different and rig it up to work … wish me luck! - Jerry K
Good luck
Hopefully when you go to install it there will be no problems and everything will fall into place.
I did post in the Tech Section with a link to this thread so any reply will probably come directly here.
So far 4 people have looked at the post but no reply.
Well, Its Kinda-sorta Working, but not like it used to. I had (and still have) some difficulty making direct crossover connections. My suspicions started when the damper motor that drives the baffle dore between freezer and fridge had different color wires on it (red with black stripe and lite blue and nor gray and lite blue) then there was only one switch connection for the damper motor and not two, so I’, left with leaving one or the other connected to the new adaptive defrost box, and I need to leave the other still connected to the old wire harness … but which one? My fix so far has been to just leave the wire off the damper motor, stopping it mostly closed. and I might fuss with it leaving it more or less open until the temps are OK, but this is somewhat of a Rube Goldberg fix and not exactly right. and as a certified NASA Nerd, I want it right!!!, so some further guidance is needed! (is it possible they sent me the qwrong Adabtive Defrost board?)
- Jerry K
I doubt it is the wrong board.
It is supposed to be a universal kit and probably fits lots of older units.
I just wish I could find some info on it, as it is unusual that they do not include an install sheet.
I am off to the cottage for a few days so will be unavailable.
Perhaps try a new post about install help for this kit perhaps then someone will jump in with some fresh info.
