Freezer not freezing
Brand: Frigidaire
Model Number: LFFU17F5HWD
Main Symptom: Not freezing
What happens & when: Gets cold but does not freeze
If possible could you remove the access cover inside the cabinet, while the freezer is running, and take a picture of the evaporator? If we could see the frost pattern or any ice build up it would help with diagnosing your issue
