Freezer not cold enough, fridge working
My freezer has been warming up off and on for a week now, when it warms, the ice melts and food is not frozen, but the fridge is working fine. Now after a week of off and on, the freezer is not cool enough to freeze the water in the ice maker. The fridge is still working fine. Where should I start to troubleshoot?
Frigidaire FRS26H5ASB5
I checked the back panel inside the freezer and there is a large amount of frost on the cover. After I clear that away, what should I do to troubleshoot?
Parts for Frigidaire FRS26H5ASB5 Refrigerator - AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389608.pdf
I am going to assume that the compressor and it’s fan run all the time other than when the unit goes through a defrost cycle.
Also that the evaporator/freezer fan is running.
If not then the below may not apply.
First remove the evaporator cover in the freezer so you can see the coils.
If they are heavily iced/frosted over then it is a defrost problem.
Do not let them de-ice.
If yes.
Manually force a defrost cycle, see the tech sheet. When the fans and compressor turn off, you are in defrost.
Now check the defrost heater (item 14 in section 13) to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the adaptive defrost board (item 23 in section 11) needs replacing, re: it is not automatically programming a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 14 in Section 13) from the wiring and measure it for continuity, should be around 30 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 21 in Section 13) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
