Brand: Model Number:RF28R7351SR Main Symptom:freezer light stays on What happens & when: 1
10 days ago I wrote to WilliamM (see image of response below). checked the area under the drawer (trapazoid like thing) and the reed switch on side of cabinet and light didn’t go out. He said it could be reed switch and I Ordered a new one, replaced it (really easy) and the light didn’t turn out. I got frustrated that I didn’t hear back from him and finally contacted parts dept. who told me he was out of office, and suggested I start a new link.
By the way, I put the magnet on the trapazoid thing on the door, and there is definitely a magnet in there. All the parts are clean too. Can it be a board? And where would that be?
My understanding is that a fan goes one when the light is on, so I’m afraid I’m burning up that fan.
Please help me fix this.
Oh, and if it happens to be a board, I can probably replace that myself as well as practically any other part I can get to. thank you so much in advance. Barb
Error Code (if any): no error code
Parts or tests already tried: Installed new reed switch. Problem still exists.
Since the frig went out then turned back on, do you think it’s a control board? I checked with samsungparts if they had the board you suggested, but they said it wasn’t the one for my model and gave me DA94-04603A.
Please let me know if there is anything else to try before buying this board. You have it in stock.
One other question: is the reed switch on cabinet door and the magnet in the plastic trapazoid thing on the rail of the drawer the only parts to control the freezer light except for a faulty control board?
hello. The frig has turned completely off then back on again after several minutes 3 times since Friday. I ordered a control board, but it hasn’t come yet. Do you think the control board is the problem?
Can the fan over heat or something and trip something in the frig that cools down and turn on again? Is that possible?
Some of the electronics on these newer refrigerators have signals built into the fan motors that communicate back and forth from the fan to the board, yes it is possible.
I received the correct control board yesterday, and this morning, I replaced the board with part #: DA94-04603A.
Happy to report the problem with the freezer drawer light not going off is fixed! The fan must have been running non-stop because the refrigerator has dropped 4 degrees over the past several weeks.
