Shut off water to Frig because water was running down the inside of my freezer behind the ice maker. What might be the problem?
Water inlet valve stuck open because of wear or trash in line.
Unless you’re talking about the water runs down when it fills the ice mold. Then your fill tube could have come loose or stopped up with ice because of a leaky inlet valve.
