Freezer Door handle clip
I have a door handle for my Amana freezer, that is loose and comes off. One of the clips that holds the handle on is broke. Do I need to replace the whole handle or can I just get the clips?
Hi.
According the diagram you can replace the clip only if you are sure that the handle is not broken.
The clip AP4081481
Here are the breakdown diagrams and Replacement parts for Amana ABD2533DEW REF - BOTTOM MOUNTS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
That part doesn’t look like the one I would be replacing. How does it attach to the door?
Hi.
Here is the only diagram I could find Freezer door replacement parts for Amana ABD2533DEW REF - BOTTOM MOUNTS | AppliancePartsPros.com
Looks like the clip is held by the screw. Try to remove the handle and see your self.
Simon.
my freezer door has 2 screws in the door, the handle has 2 clips, with a hole and slot in each, the screws extend into the holes and the handle is slid to the left to lock on. One of the clips is broke.
