Hey there! On your Frigidaire GLFU1467FW0 upright freezer, the CE error code generally points to a communication problem involving the electronic controls.
Since the freezer also won’t turn off, I’d start by checking the control system before replacing any parts.
Here’s what I’d recommend checking
1. Reset the freezer. Unplug it or turn off the circuit breaker for about 5 minutes. Restore power and see whether the CE code returns.
2. Check the temperature controls. Try adjusting the temperature setting and see whether the display responds. If the buttons aren’t responding or the display remains stuck on CE, that could indicate a control problem.
3. Inspect the control connections. Unplug the freezer before opening any panels. Check for loose connectors, corrosion, damaged wiring, or moisture around the electronic control.
4. Check the actual freezer temperature. Place a thermometer inside and monitor it. If the compressor runs continuously and the freezer gets much colder than its normal setting, that could indicate a temperature-sensing or control issue.
One other thing worth checking: make sure the display isn’t locked. According to Frigidaire’s control guide, holding the Alarm Reset button until it beeps locks or unlocks the display. The same guide identifies CE as a system error.
Canadian Appliance Source+1
If the code returns after resetting power and the wiring looks good, the main electronic control board or display control board becomes a likely suspect.
A couple of questions
When you say the freezer won’t turn off, do you mean the compressor runs continuously, or that the control panel won’t let you turn the freezer off?
Is the freezer maintaining a normal temperature around 0°F, or is it getting excessively cold?
Does CE appear immediately after plugging it back in?
Those answers will help narrow down whether we’re dealing with a control communication failure or an additional cooling problem before you spend money on parts.
The freezer has been unplugged for a day. I plugged in about 3 hours ago. I pushed the reset button until it beeped. The compressor has been running and the temp. dropped to about 16 degrees. The outside display reads 55 degrees. I am going to give it 24 hours to stabilize. If I try fast freeze, the light comes on and then goes out within 10 sec.
Question, does the display indicate freezer is in locked mode in some way?
Thanks for the update! The fact that your Frigidaire GLFU1467FW0 freezer is running and has cooled to approximately 16°F after just three hours is encouraging. That tells us the compressor and cooling system are working.
As for your question, the display reading 55°F does not indicate that the freezer is locked. A control lock normally affects the buttons, not the temperature reading.
I agree with giving the freezer a full 24 hours to stabilize before making any decisions about replacing parts.
There are two things I’d like to keep an eye on:
The temperature display: If the actual freezer temperature continues dropping toward 0°F but the outside display stays at 55°F, we may have a temperature-sensing or electronic control issue.
The Fast Freeze button: The light coming on and then going out after approximately 10 seconds isn’t something I’d automatically consider normal. It could indicate the control isn’t maintaining that setting.
I checked the Frigidaire control instructions, and there is a specific way to identify the lock status:
LO: Control is locked.
UL: Control is unlocked.
To toggle the lock: Press and hold the Alarm Reset button until you hear a beep. The display should briefly show LO or UL.
Extreme Freeze: When successfully activated, the display should show FF, and the feature normally remains active for up to 72 hours.
Since you’ve already held Reset until it beeped, you may have changed the lock setting rather than simply resetting the alarm.
One quick question: When you press the Fast Freeze button, does the display briefly show LO, FF, or just 55°F?
That will help us determine whether the controls are locked or whether we need to investigate the display/control system further.
Thank you for your help. When I push fast freeze FF shows on display for a second and then goes to 55 degrees. Also when I try to lock I hear a beep but display continues to read 55degrees. My thermometer bottoms at 16 degrees but I believe freezer is closer to zero. Compressor still running.
It has been over a day and same thing, freezer is very cold but running continuously and reads 55degrees.
On your Frigidaire freezer, model GLFU1467FW0, the fact that it’s getting very cold while the display continues to show 55°F makes me suspect a problem with the temperature sensor (thermistor), its wiring, or the electronic control.
The compressor running continuously is another important clue. If the control thinks the freezer is still at 55°F, it may keep calling for cooling even though the freezer is already near 0°F.
The Fast Freeze and Lock behavior doesn’t necessarily mean those buttons are defective. We need to determine why the control keeps displaying 55°F.
Here’s the next test I’d recommend. I found the Frigidaire diagnostic procedure for this freezer.
Use the temperature arrows to set the freezer to 0°F.
Press and hold both temperature arrows together until the display shows 88.
Press Alarm Reset to check the thermistor.
The results should be:
-- means the thermistor circuit tests normal.
0 means the thermistor circuit is open.
S means the thermistor circuit is shorted.
Frigidaire also confirms that a thermistor failure can cause the compressor to run continuously as a protective measure.
If we find a thermistor problem, we can check its resistance with a multimeter before replacing anything. The service information specifies approximately 10,000 ohms at 70°F.
One question: When you enter diagnostics and press Alarm Reset, does the display show --, 0, or S?
That result will help us narrow this down without guessing at another part.
Also, since your thermometer cannot read below 16°F, I’d recommend getting a freezer thermometer that reads below 0°F. We don’t want the freezer getting excessively cold while the compressor continues running.
For some reason the freezer is no longer flashing CE but now flashes D and 55degrees alternately. It still runs continuously. It is still very cold. ideas??
That’s an interesting change. Since your Frigidaire GLFU1467FW0 freezer is still getting very cold but continues running, I’m leaning toward a temperature-sensing or electronic control problem rather than a compressor or sealed-system issue.
The fact that the CE message disappeared and the display now alternates between “D” and “55” is another clue.
Here’s what I’d check next.
Check the actual freezer temperature. Place a thermometer inside and see whether it’s holding around 0°F or dropping well below that. If it’s getting down to -10°F or colder and never shuts off, the control may not be recognizing the correct temperature.
Check the freezer thermistor. A defective sensor or damaged wiring could make the control think the freezer is warmer than it really is, keeping the compressor running.
Inspect the control connections. Unplug the freezer and check the wiring connections at the electronic control, particularly the temperature-sensor circuit. Look for loose terminals, corrosion, or damaged wiring.
I would hold off on purchasing another control board until we narrow this down.
One important detail I found in the Frigidaire error-code information: “d” indicates the control thinks the freezer door is open, even if it’s actually closed. That makes the door switch our best next check.
Sears PartsDirect
Try pressing the door switch by hand with the door open. See whether the interior light goes out and whether the “d” disappears.
Two questions:
When you press the door switch, does the interior light turn off?
Is the display showing a lowercase “d” or an uppercase “D”?
Those answers will help us determine whether we’re dealing with a door-switch problem or need to investigate the control and temperature sensor further.
Thanks again for the help. First, the d on the display was small case. Interestingly when I unplugged to check the display control(contacts and wires looked great) and plugged it back in, the d code was replaced with CE but the temp reading dropped 16 degrees. I took control off again in plugged it and put it back together and display demo dropped to 10 degrees which may be where I set it.
Thanks for the update! These latest results are actually very helpful, and I think we’re getting closer to identifying the problem with your Frigidaire freezer, model GLFU1467FW0.
The biggest clue is that the displayed temperature changes dramatically every time you unplug and reconnect the freezer. You’ve seen 55°F, 16°F, 10°F, and now -25°F. You’ve also had the CE error return, and the compressor continues running even when the display says OFF.
I’m now more suspicious of an electronic control or communication problem than a refrigeration problem.
Here’s why:
The changing temperature readings: A temperature sensor could be sending incorrect information, but the large changes immediately after reconnecting power also suggest a control-board or communication issue.
The CE error: This generally points toward a communication problem between electronic controls. Even though the connections look clean, that doesn’t rule out an internal board failure or an intermittent wiring connection.
The compressor continuing to run: This is particularly important. If the freezer is actually receiving an OFF command but the compressor keeps running, the control may not be switching the compressor off properly.
I wouldn’t purchase another part just yet. There are two checks I’d like you to make first.
1. Verify the actual freezer temperature.
Place a separate thermometer inside the freezer and compare it with the display after several hours.
If the thermometer reads around 0°F while the display jumps between temperatures, that supports an electronic sensing or control problem.
If the freezer really is reaching -25°F, we may have a control that isn’t shutting the compressor off when it should.
2. Check whether the compressor actually shuts off.
With the freezer running, use the control panel to turn it OFF.
Wait a few minutes, then listen near the bottom rear of the freezer. We want to know whether the compressor itself continues running or whether you’re hearing a fan.
If the compressor continues operating with the display showing OFF, that makes the main control’s compressor-switching circuit a stronger suspect.
The CE code is consistent with a communication fault involving the user control and main electronic control.
PartSelect
My recommendation
Since you’ve already inspected the display connections and found nothing obviously wrong, I’d concentrate on the electronic controls and their wiring before replacing the temperature sensor.
One important question:
When you turn the freezer OFF using the display, does the compressor at the bottom rear continue humming and vibrating, or are you only hearing a fan running?
That distinction will help us determine which control to investigate next.
Also, until we confirm that the freezer can regulate its temperature, I’d monitor it with a separate thermometer rather than relying on the display.
