How often should a freezer cycle on and off? Mine stays on for about 17 minutes then turns off for about 9 minutes and then back on. These times fluctuate ± a minute. Is this about right or is it staying on too long and turning back on too soon?
Can you post your model number?
What is the temp inside the freezer?
Nat
If your temp is OK, Don’t worry about it!!! The run time is governed MANY factors,Some of which, you control, and some you can’t It sounds about right, Don’t worry!!!
The model number on the inside on the door is Model 25358. I also found another number which is 106.8253581.
Ok how much stuff do you have in the freezer?
It’s pretty full. The whole problem started when the compressor got too hot and the relay was clicking and not letting the compressor turn back on. I’m not sure what caused it. It almost acted like the door was left open but it wasn’t. I have been checking it for over a week now. I put a fan on the back pointed toward the compressor and it seemed to help. I turned off the fan today and it has been cycling as stated in a prior post. I’m just not sure if it is okay or if there is something wrong with it. The temperature inside is about 2 degrees.
Clean your coils very good and test your start device, I think that’s where your problem is, there’s full discriptions posted in another thread if you need them…![]()
Nat
your fridge is running less then 50%,this is ok there no problem with that run time.There no problem with your fridge/freezer..
Nat,
The coils are clean so that isn’t an issue. I don’t know how to test the start device. It starts and stops okay but seems to run longer and more often then it should.
Abbie,
I have never timed a freezer before so I didn’t know if the cycles were normal or not.
Well unless the’ve changed math it’s running almost 66% of the time. Are you in and out of the freezer a lot? If it’s starting & stopping ok now, lets check the door seal. take a dollar bill and close it in the door all the way around, if it pulls out easily then that may be causing it to cycle more.
Is the start device still clicking a lot?
Nat
I thought the problem was solved. I took your advice and checked the seal. The door while closing wasn’t shutting tightly. I checked to make sure nothing was blocking it and like something sticking out from the shelves and found nothing. I pulled out the bottom drawer and found an ice pack behind it. It was pushing out the drawer just enough so it wouldn’t completely seal.
That didn’t seem to make any difference. The freezer ran for over 20 minutes and i opened the door to check the temperature and it was still 2 degrees. It started back up but shut off because the compressor was too hot. I have unplugged it to let it cool down. My thermostat goes from 1-5, 5 being the coldest. I have it set at 1.5, doesn’t that seem awfully low for a freezer? I’m at a loss now.
I would suspect your temp control, if you hav it set that low and it’s now running over 20 min. How long is it off between cycles now? Nat
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Okay here are the cycle times since correcting the problem that kept the door slightly ajar. The door was never opened during these times. It was better before I fixed the door (on 16 off 9). I think I’ll block the door open again.
[/COLOR][/SIZE][/FONT]
[SIZE=3][FONT=Times New Roman][COLOR=#000000] [/COLOR][/FONT][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]On: 19.0 minutes[/COLOR][/SIZE][/FONT]
[SIZE=3][FONT=Times New Roman][COLOR=#000000]Off: 2.30 – I don’t know what happened with these next two times. I set my watch timer and went up stairs to pour a cup of coffee and came back down stairs and it was running again, so it was only off for about 2.30 minutes. [/COLOR][/FONT][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]On: 2.0 – Then it only ran for about 2 minutes.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Off: 10.26 – It seems to have gotten back on track now.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]On: 22.10[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Off: 10.28[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]On: 21.39[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Off: 10.27[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]On: 21.25[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Off: 10.25[/COLOR][/SIZE][/FONT]
Those times seem to be somewhat normal, Is there a reason that you are so concerned with the run times? Temp?, Power bill? Noise? ![]()
I’m concerned there is something wrong with the freezer and it will stop working while I’m on vacation. I opened it the other day after it had just shut off and after I closed it the compressor started up and then shut off and then tried to start again and then shut off. I believe the start relay was preventing it from coming on because the compressor was too hot which is what I noticed happening a couple of weeks ago which started this whole fiasco. I unplugged it and let it coold down for a couple of minutes and then plugged it back in and it started up no problem. It just seems to be acting strange.
Do you know if you had a power outage or power surge before you noticed that the compressor was that hot? It’s running more than 75% of time.
Nat
PS personally I can see your concern.
I don’t think we had any power problems. I was just logging the cycle times and then had to open it to get something out and then heard the start relay clicking again just like it did a few weeks ago.
If it was low on freon I should see some sort of residue from where it leaked out shouldn’t I?
Not unless there is a definate leak and the compressor oil can be seen. Do to the age I don’t think the drier had the dye in it then and that requires a special light & glasses to see.
without checking your freezer ourselves, I think the overload inside compressor was damaged. Causing it to cycle incorrectly.
If you have concerns call a tech in your area and have them check the system thoughly.
Nat
Okay thanks Nat.
last time i did the math on a 17min run an a 9 min off cycle it less then 50% Cujok i,am only in the refrigeration trade for 28 years my license#is88-859 there,s nothing wrong with your fridge/freezer.
