Freezer cold Fridge Warm
Hi I have a issue with my Frigidaire side by side. The fridge temp got up to 50 before I ended up taking it apart. After some work I noticed the fan was not running in the freezer. When I started taking apart the back panel in the freezer section the fan kicked on, when I took the back panel off I noticed a wire that clips on to the upper left corner of the aluminum housing, is this some sort of ground that may have been jolted and started the fan? Also I noticed the whole evaporator core was all encased in ice. It took me about 40 mins with a heat gun to deice it. Is it possible that the stopped fan caused so much ice buildup that the defroster couldn’t handle defrosting all the ice, or is there something wrong with the defroster? If its the defroster how do I go about testing the various components? I got the fridge working but I don’t want to have it freeze up on me again. Also can someone post or send me diagrams on this fridge? Thanks in advance…Brian
Model: plhs268zcb0 Frigidaire side by side
Replacement parts for FRIGIDAIRE PLHS268ZCB0 Frigidaire/refrigerator | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389608.pdf
Here are a couple good sites with additional help
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
http://www.applianceaid.com/frig.html
[COLOR=“Blue”]I noticed a wire that clips on to the upper left corner of the aluminum housing, is this some sort of ground that may have been jolted and started the fan?[/COLOR]
Not sure but you may be looking at the defrost thermostat.
[COLOR=“Blue”]Is it possible that the stopped fan caused so much ice buildup that the defroster couldn’t handle defrosting all the ice, or is there something wrong with the defroster?[/COLOR]
Sounds like you have a defrost problem. A stopped fan will not cause it to ice up. If the fan is receiving 120 volts AC and not turning, it needs replacing.
[COLOR=“Blue”]If its the defroster how do I go about testing the various components?[/COLOR]
See below. The tech sheet says how to force a defrost cycle.
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
Manually force a defrost cycle (see the Tech Sheet) the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer/adaptive defrost board needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item in Section ) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item in Section ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Thanks for your help Denman I’ll try out all the procedures to find the problem…Brian
