Freezer Alarm beeping, but cold and constantly running
I have a Frigidaire chest freezer model glfc2528fw2. The temperature alarm has been beeping constantly and the compressor is also running all the time. I used a freezer thermometer and it shows about -30 F. Based on the other postings on here I replaced the thermostat, however, this didn’t help and it is still doing it. What else should I be looking at? I have seen lots of suggestions from the wiring harness to the high voltage control assembly, but I don’t want to just keep replacing parts. What else could it be?
Did you ever find out the temp alarm constantly beeping?? Mine does the same?
