Brand:lg
Model Number:dle151w
Main Symptom:flow sencer
What happens & when:wen dring
Brand:lg
no error code that know of
The Flow Sense warning on your LG dryer indicates that the dryer is detecting restricted airflow. This doesn’t necessarily mean you have a bad sensor. Most of the time, the problem is a restriction in the exhaust vent.
I would start with the following:
I would avoid replacing any parts until we have ruled out an airflow restriction. Restricted airflow can cause overheating, extended drying times, and premature thermal fuse failure.
A couple of questions:
the modle number was wrong the right one is dle15101w
Thanks for checking! The Flow Sense warning on an LG electric dryer is primarily an indication of restricted airflow, rather than a failed sensor. I would check the exhaust vent before replacing any parts.
The closest verified model number is LG DLE1501W, which has a built-in airflow diagnostic test.
ManualsLib+1
If the warning persists after confirming the exhaust vent is clear, unplug the dryer and inspect the following:
Keep in mind that the Flow Sense warning may take several complete drying cycles to clear after correcting the airflow restriction.
ManualsLib+1
Is the dryer taking longer than normal to dry your clothes, and have you tried running it briefly with the exhaust hose disconnected? That would help us narrow down the problem.
