how many ohms does a flat igniter have??
Oven igniter resistance is not important as long as it has some.
More important is a current drawn by igniter. For a flat igniter it suppose to be between 3.2 amps to 3.6 amps.
You can learn how a flat oven igniter works from one of previous posts: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1897-oven-wont-lite.html
Most of flat oven igniters (excluding igniters with blue ceramic) are interchangeable. Both oven igniters you’ve mentioned in your previous posts are good for your oven.
- The part number for the gas safety valve is [COLOR=#0066cc]AP2131109[/COLOR]
P.S. Do not reply on you own thread unless someone else did it - it makes your thread look too old and like it’s been already answered.
gene, thanks for the reply !! i just ordered a safety valve. i almost bought a new gas range, but i’ll give it one last try .. thanks again
Keep us posted.
thanks again for your help!! i installed the new safety valve today and the oven fired up. all is well that ends well!!
We are glad you were able to fix it.
